WAB - Print Plus Spatial Reference
2325
08-09-2016 11:06 AM
RickeyFight
MVP Alum
I have found a way to fix the spatial reference so the scale is accurate when printed to my projection.
The problem now is that when I print the map prints larger then the defined box.
I think that it prints bigger to preserve the scale that has been set.
I tell it to print at 1=40 but when i compare the print to the slider it has actually printed the area of at 1=55 at 1=40 scale.
I am trying to wrap my head around this.
Do I just need to change the config file to match the new size of the print.
RickeyFight
MVP Alum
I believe the solution is just to make the page size bigger in the config even though I printing at 8.5x11.
My config says the page is 11.65x14.8
    "Elevation8x11Portrait": {
      "alias": "Elevation8x11Portrait",
      "units": "esriInches",
       "params": [
          "x": 11.65,
          "y": 14.8
          "x": 11.2,
          "y": 13.5
          "x": 0.225,
          "y": 0.8
          "x": 0.5,
          "y": 0.5
RickeyFight
MVP Alum
       "params": [
          "x": 11.65,
          "y": 14.8
          "x": 11.2,
          "y": 13.5
          "x": 0.225,
          "y": 0.8
          "x": 0.5,
          "y": 0.5
Kara_Lara
Additional details in my reply here  Print Plus Widget Layout
