WAB - Edit Widget
4345
10
05-01-2018 08:35 AM
RickeyFight
I am working on Web AppBuilder Custom Widgets‌ that when a user clicks on an edit template the toolbar will minimize. I need this because I am trying to edit on a mobile device and the toolbar take up too much of the screen.
Thanks!
GeorgeKatsambas
Thanks Robert, that is how it is set up now, certain AGOL users (10 in a shared group) who use the Collector App to collect field data, however, in this AGOL Group 1 or 2 individuals would like the possibility to go into the editable feature service  attribute (that is published) and use the edit widget through a password and change more than just the one editable field I have set up in the WAB app and online map. Right now I use the online AGOL map to make 1 field editable only, then in the widget the same thing, however, now with WAB 2.10 I can set the edit widget to honor the online map editable fields..
