WAB Delete Confirmation
3227
02-09-2016 05:12 PM
HamishKingsbury1
Hi All
I would like to add a confirmation dialog box to appear when a user clicks either the:
  • delete button from the feature popup or
  • delete icon from the editor widget
I've had a look at the JS api hoping their might have been an event but haven't made any progress.
Has anyone implemented a confirmation?
Cheers
Hamish
NNDCDNNDCD
This should be built in functionality. Why is this not built in and why is it so difficult to implement? I can't find the click event to intercept to add my own confirm dialog. Has anybody been successful in doing this?
RobertScheitlin__GISP
All,
   The issue is that there is not just some event that you can listen for in the JS API so it becomes pretty difficult to listen for a feature delete. Adding a event listener to the popup would not be that difficult but the delete button on the edit toolbar in the edit widget is a whole other situation. If you could just hit the delete key on the keyboard (by accident) then I would see the real need for a confirmation dialog but the fact that a user has to click on the delete button should mean that the user does want to delete the feature and a confirmation would just add a additional nuance step (in my opinion).
