Using extent values of Basemap, I want to use extent values of the Map Service used in WAB?
3730
07-25-2015 01:33 AM
RahmathUnissa
I am using a custom widget which is used to draw an extent and retrieve the XMax,Xmin,YMax,YMin values of the used Map Service but in WAB it is returning  the extent values of the basemap. Also, the spatial reference is different for both Map Service and BaseMap.
How Can I get the Map Service's extent values??
RobertScheitlin__GISP
Rathmath,
    If the basemap is in a different spatial reference then the one you need for that map service then you will have to re-project the extent drawn by the end user using the GeometryService.
Here is a quick simple example app:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var map, gsvc;
      require([
        "esri/map",
        "esri/tasks/GeometryService",
        "esri/tasks/ProjectParameters",
        "esri/toolbars/draw",
        "esri/graphic",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/SpatialReference",
        "dojo/_base/lang",
        "dojo/on",
        "esri/symbols/SimpleFillSymbol",
        "dojo/domReady!"
      ], function(
        Map,
        GeometryService,
        ProjectParameters,
        Draw,
        Graphic,
        ArcGISDynamicMapServiceLayer,
        SpatialReference,
        lang,
        on,
        SimpleFillSymbol
        map = new Map("map", {
          basemap: "topo",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [-122.45, 37.75], // longitude, latitude
          zoom: 13
        gsvc = new GeometryService("http://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        var dLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver5.arcgisonline.com/arcgis/rest/services/911CallsHotspot/MapServer");
        map.addLayer(dLayer);
        on(map, 'load', createToolbar);
        function createToolbar() {
          var toolbar = new Draw(map);
          toolbar.activate(Draw.EXTENT);
          toolbar.on("draw-end", addToMap);
        function addToMap(evt) {
          map.graphics.clear();
          evt.target.deactivate();
          var graphic = new Graphic(evt.geometry, new SimpleFillSymbol());
          console.info("In Geometry: ", evt.geometry.xmax, evt.geometry.xmin, evt.geometry.ymax, evt.geometry.ymin);
          map.graphics.add(graphic);
          var params = new ProjectParameters();
          params.geometries = [evt.geometry];
          params.outSR = new SpatialReference({wkid:102726});
          gsvc.project(params, lang.hitch(this, function(geomsArr){
            console.info("Out Geometry: ", geomsArr[0].xmax, geomsArr[0].xmin, geomsArr[0].ymax, geomsArr[0].ymin);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
Rathmath,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        overflow: hidden;
    </style>
    <script>
      var map, gsvc;
      require([
        "esri/map",
        "esri/graphic",
        "dojo/_base/lang",
        "dojo/on",
        "dojo/domReady!"
      ], function(
        Map,
        GeometryService,
        ProjectParameters,
        Draw,
        Graphic,
        SpatialReference,
        lang,
        on,
        SimpleFillSymbol
          zoom: 13
    </script>
  </head>
  <body>
  </body>
</html>
RahmathUnissa
Thanks Robert
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
