Use single sign-on username in Web AppBuilder filter widget?
2842
09-27-2019 06:26 AM
Bud
Legendary Contributor
I have a web map:
enter image description here
Details:
  • The map has a Web AppBuilder filter widget
  • It uses single sign-on (SSO) authentication
The map has a layer that is integrated from a table in a separate system. Each record in the layer has a USERNAME value (example: JSMITH).
I would like to configure the map so that it:
  1. Grabs the SSO username that it used to authenticate the web map
  2. Filter the records based on the username
What would it take do this? (filter the layer based on the SSO username)
Sorry if I haven't provided enough information about the web map. I really don't know much about the it, but perhaps I could find out more if there are specific questions.
KenBuja
MVP Esteemed Contributor
You should mark this answer (and the Stack Exchange answer) as correct to help those with this question.
LouisDECOMBE
Hi Bud,
want to know if you succeed to filter you layer by SSO Username Portal.
I don't realy see how and where to changer filter Filter/Widget.js and where I can find this widget for my apps.
Regards
Louis
