Trying to figure out how to edit custom widget ?
1155
06-28-2020 09:20 PM
by Anonymous User
Not applicable
So I'm pretty new to WebApp builder developer edition. I'm just trying to do a simple task to list the layer in the console log by clicking the button inside the widget.
This is what I have so far. it keeps saying "Uncaught TypeError: LayerInfos.getInstance is not a function" So I'm pretty sure it can't find 'jimu/LayerInfos/LayerInfos'. Also VisualStudioCode greys out the LayersInfos on line 8 when decalring the functions.
I'm using the xxxxxxxxx:3344/webappviewer/?config=sample-configs/config-demo.json  to develop the app.
Could anyone help guide me. I think I'm missing something fundamental here.
define(['dojo/_base/declare',
  'jimu/BaseWidget',
function(declare, BaseWidget, LayerInfos) {    //LayerInfos gets greyed out in Microsoft Visual Studio
  var clazz = declare([BaseWidget], {
    templateString: '<div>This is adamsWidget!. ' +
    '<input type="button" value="Get Map Id" data-dojo-attach-event="click:_test">.</div>',
    _getMapId: function(){
      //alert(this.map.id);
      console.log("im in here!")
    _test: function(LayerInfos) {
      LayerInfos.getInstance(this.map, this.map.itemInfo).then(function(layerInfosObject){
        layerInfosObject.getLayerInfoArray().forEach(function(layerInfo) {
            console.log(layerInfo.title, layerInfo.id);
  console.log("YsES")
  return clazz;
RobertScheitlin__GISP
Adam,
    You issue is in your _test function.
//You have
//You need
_test: function() {
The issue is having LayerInfos as a parameter to you function means that it is expecting the method that calls the _test function to pass the LayerInfos parameter.
