set tab title from nls
4604
16
05-10-2017 02:47 PM
LefterisKoumis
I am trying to assign a title to a tab from the nls.strings, however I get this error. The only way is to assign the title is by using the widget.js? Thanks.
HTML:
<div data-dojo-type="dijit/layout/TabContainer" style=" height: 700px; width: 630px; " >
<div data-dojo-type="dijit/layout/ContentPane" title=${nls.subjectA} >
nls.strings.js
define({
  root: ({
    subjectA: "Subject A",
LefterisKoumis
The actual widget is 3 times bigger so I created this smaller version so I can send it to you. The original widget does not have any syntax errors but it seems when I created these two files in the smaller version, I rushed. The original string.js and  widget.html have the same scripts as the ones you posted here and I get the error that I stated in my original posting.
Thank you.
RobertScheitlin__GISP
Lefteris,
  Well I really can't help if you not providing your actual widget code. When I made those changes to the widget code you provided the tabs appeared with the text just fine.
LefterisKoumis
ok. The code I provided to you without the syntax errors still shows the same error as the actual code. If you don't see the same "dijit._WidgetsInTemplateMixin template:nls.subjectA" error then I can't explain what's wrong with it. Thank you anyway.
Lefteris,
   So you must have an error in your code still then. Here is the widget you send me working:
LefterisKoumis
Thank you. I posted the zip file you provided to me and no errors appear!! This is bizarre. I run the notepad++ compare module and saw no differences between original versions of strings.js and widget.htm and the same ones in the zip filel!!!
check the manifest.json. you had haslocale as false.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
