Search for coordinates with decimal numbers separated by commas in the search widget
2303
06-02-2017 12:02 PM
GilbertoMatos
Hello!
The search widget is not doing the coordinate search correctly. In Brazil, we use the comma character as a decimal separator, but in the search widget, it is only searching for the location correctly, if I enter the coordinates, with the dot character.
Examples:
-51.1781 -29.9189 correct location
-51.181 -29.9189 wrong place.
Note: Even if I force locale = I can not do the search by separating decimals from the coordinates, with a comma.
Thanks for any help.
Gilberto.
RobertScheitlin__GISP
Gilberto,
   This sounds like a bug that you need to report to esri technical support. There is little the GeoNet community can do for that issue.
Gilberto,
GilbertoMatos
Ok!
Thank you, Robert.
Hug,
Gilberto.
