scss files
2081
04-09-2017 09:36 PM
GisGKAuckland
can someone give me links on how scss files are incorporated into a widget.
has the conversion to css to be done manually? if so what tools are preferred in WAB
RobertScheitlin__GISP
A scss file needs to run through a css preprocessor like SASS to convert it to a standard css file. So the widget does not actually use the scss file. You can use Sass to convert it.
http://sass-lang.com/
GisGKAuckland
Thanks for the same.
When you have a widget having scss files, how does one go about changing it in the current environment?
My problem is i had to change the color of a button, I opened the css and tried my lotto . It changed all over the place. Looking at the scss it was meaningful and I could pinpoint where to change it. Is there a better approach?
You would make your changes in the scss file and use sass to recompile your changes to the css file.
