Remove widget from map
3838
08-05-2015 02:37 PM
TerryGustafson
I have 3 map widgets label 1, 2 and 3. I want to remove from my map.  How do I accomplish this?
RobertScheitlin__GISP
Terry,
   If you do not assign a widget to those place holders then the finished app will not have those. If you have assigned a widget to those and are asking how to remove those then you just click the x in the upper right hand corner of the widget you have assigned to that placeholder.
Terry,
TerryGustafson
Duh!! I thought about that last night when I was at home.. Thanks for the help Again!! ☺
