Publish Data is not working in WAB 2.6
1541
09-11-2018 07:01 AM
SivaramKrishnan2
Hi
I'm trying to publish a layer to attribute table widget by using the mentioned code snippet.
Send a layer to the Attribute Table widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS fo...
In the same widget i'm trying to publish another set of data to the legend widget to display some custom legend information.
But i'm not able to see the published data in the legend widget,when i publish the layer data to Attribute table widget from the same widget(MyCustomWidget).
I can see the published layer data in the Legend widget, if the data publishing code for attribute table widget got removed.
Please help me to see both of the published data legend and Attribute table widget respectively.
Thanks & Regards
Siva
RobertScheitlin__GISP
Siva,
Are there any errors presented in the browsers web console?
SivaramKrishnan2
Robert,
Thank you for the response.
I'm not getting any error messages in the console.
Regards
Siva
That makes it nearly impossible to help then.
