Popup Panel 2.13 - Selection Display issue Dashboard Theme
1745
12-23-2019 12:10 AM
RodWoodfordOld
Hi Robert,
I'm having an issue with weird behavior re the popup panel when using the dashboard theme. Please see app below. When users click the Map Layers tab, top left of the display and turn layer on multiple layers and then click in the map display area only the first result is been displayed in the Popup panel ("Map layers result" - bottom right of display). Users can't seem to scroll between selected layers. Any advise would be useful.
ArcGIS Web Application
cheers
RobertScheitlin__GISP
I forgot to mention that same change needs to be made to the eSearch\featureActions\eZoomTo.js
Did you update the site with the code change?
Rod,
   You are running into an eSearch issue that was fix in 2.13 I think. In the eSearch\featureActions\eShowStatistics.js
Make this change (line 5).
    isFeatureSupported: function(featureSet, layer){
      var supported = false;
      supported = featureSet.features.length > 1 && layer && this.getNumbericFields(layer).length > 0;
      var tWidget = WidgetManager.getInstance().getWidgetById(this.widgetId);
      if(tWidget && tWidget.state === 'active'){
        return supported;
      }else{
        return false;
RodWoodfordOld
Hi Robert,
Thanks for the prompt reply. No that didn't resolve the problem.
cheers
RodWoodfordOld
Thanks Robert. Yep that did the trick. All good now. Thanks for your continued development and help over the last 12 months. Have a great Xmas and New Year.
cheers
Rod
