Pop Up arbirtrarily size change
2280
04-11-2016 09:32 AM
LefterisKoumis
Hello folks.
I'm using the local layer widget and I configured the popups. I noticed that after the initially the map is drawn and you zoom in and out, when you click on a feature the popup is minimized and cannot get it to its original size. Anybody noticed this behavior? Thank you.
Original pop-up
Minimized pop-up
LefterisKoumis
Bummer. Nobody has an answer to this or experience it?
RobertScheitlin__GISP
Nope never seen it.
Are you sure you don't have some map.infoWindow.resize(blah, blah) in your code somewhere?
LefterisKoumis
Thanks for replying Robert.
I searched everywhere to see if somehow in the myriad of coding I inserted a infoWindow.resize and forgot about it, but nothing showed up.
