Measurement Result not displaying
1705
04-01-2019 02:02 AM
KafilBaig
I added Measurement widget it doesnt display the result. Any other setting i need to do.
Measure ConfigurationMeasure Result
Tags (1)
RobertScheitlin__GISP
Kafil,
   What version of WAB are you using?
KafilBaig
I am directly launching wab from Portal for ArcGIS 10.6.1.
Sent from my iPhone
Kafil,
   OK. Portal 10.6.1 uses WAB 2.8. I just tested 2.8 and did not have any issue using the measurement widget. Are you using a custom basemap in your webmap for that application? If so what is the WKID of your basemap?
KafilBaig
Am using EPSG:28600
Qatar 1974 / Qatar National Grid
Sent from my iPhone
I have not seen this issue. My only advice is to contact your local esri distrubitor for tech support.
