LDockable panel
5255
12
10-03-2016 01:34 PM
DouglasLecker
Hello all,
   I am trying to use the LDockable panel functionality from the Jewelry box theme to my custom theme, but I can't figure out where to put my widget for it to register it in the config.json that one is present. The panel only shows up in the Jewelry box if you put a widget in in when you create the map. Has anyone tried to use this panel in their theme's?
Thanks for the help.
    Doug
DouglasLecker
Thank you very much for your help Daniel. Now I just have some css to tackle and I think I will be good to go.
Cordially,
    Douglas
DouglasLecker
Hello Dan,
    I have another issue with the LDockable panel. I moved it to the right side of the layout, but the map position does not change anymore. I have reversed all the code to the changeMapPosition in the panel, but it is still opening up on top of the map. Any Idea what I might be missing?
James_001
Robert,
I tried but not sure exactly where is that code and how it works, can you please help me.
