Layer List Widget - Radio Button Option
8449
11
03-17-2016 11:02 PM
RodWoodfordOld
Will the next release of WABD include an option to configure radio buttons over check boxes in the Layer List Widget. At the moment the user is required to turn a layer off and another layer on when they only want to display one layer at a time, its very messy to work with especially when ticked on layers sit above the chosen layer hiding its required vision. It confuses end users. Basically trying to switch between aerial images.
If there is another widget out there that can do this, please advice.
cheers
Rod
Tags (1)
RobertScheitlin__GISP
Rod,
  I do not know of any plans to add this ability to the LayerList widget. I have only every seen a handful of people desire this in the many years I have been doing these forums so it is more of a case for someone to do a custom development then to have it as part of the core widget.
RodWoodfordOld
Thanks for getting back to me Robert. I thought that would be the case. I did look at the AddLayer Widget to see if it had this type of functionality. It doesn't from what I can see. Maybe this widget has the potential for this type of development. Do you have anymore ideas re this. Our staff are really frustrated with the current workflow using the layer list widget. Especially since our previous flex app could achieve the desired outcome via radio button selection. Thanks for your time
Rod
KenBuja
MVP Esteemed Contributor
The LayerList widget in the 4.0 API will have this capability, so Esri must be aware of a need for this. How long it will take to make this into the WAB is another question, though.
Ken,
  I missed that info. Where did you see or hear that?
KenBuja
I wasn't quite right. It's the visibilityMode property of the GroupLayer, which gets reflected in the LayerList. If you look at the plenary video "ArcGIS APIs and SDKs", starting at the 8:05 mark, you'll see it in action.
JamesCrandall
I sure hope they make the print widget work with this setup as well   --- as it is right now, map services with grouped layers don't even get added to the legend!
RodWoodfordOld
Thanks for the info Ken. Now we just wait for ESRI to catch up I guess!!!
Rod
by Anonymous User
Not applicable
Ah Ken Buja​ thank you for your input, and your many samples dealing with layers and TOCs over the years.
Since we're talking TOCs, do you all think having partial-state check boxes for when only some of the layers in a group are on but not all of them would be useful?
(I think this would even be useful for ArcMap Desktop)
All,
   Here is a thread where I came out with some code for sublayer checkboxes to act like radio buttons (i.e. only one sublayer enabled/visible at a time).
https://community.esri.com/thread/182116-layerlist-21-option-to-displays-sublayer
