Is it possible to select by multiple locations in MapViewer and get a pop-up of summation information for the selected areas?
947
02-13-2020 10:28 AM
ScottHansen__MDP_
I have a statewide map with Census tracts I would like to display in MapViewer.  Do I have the ability to: (1) draw a point, line or polygon on the map to select several census tracts and (2) display a pop-up that illustrates total population for the multiple tract area, not just a single tract? I assume an Arcade expression can handle the pop-up but the select by location functionality is what I am getting stuck on, assuming that functionality exists within MapViewer.  I am not interested in filtering. Your help is much appreciated.
XanderBakker
Esri Esteemed Contributor
Hi [email protected]_maryland ,
The pop-up won't be able to do this, since it will need a single feature to start with and you are working with a selection. However, if you provide an editable layer where you can draw point, lines or polygons, you can define a pop-up with an Arcade expression on that layer that will provide you the result.
