How to Style a Modal Panel for Mobile Devices
1026
09-14-2016 11:34 AM
WilliamMiller4
I'm using the modal panel from the WAB Create a New Panel tutorial. I modified the Foldable theme to use the modal panel to open a group located in the header controller. The group has a single widget in it. This works fine on desktops (see first image below), but I'm having trouble styling the widget for mobile devices (see second image below). I tried using the Splash widget as a guide to modify the widget, but it doesn't seem to work. Do I need to add mobile styles to the modal panel instead of, or in addition too, the widget? Any help is greatly appreciated.
Thank you,
William
Modal Panel with Widget on Desktop Computer
Modal Panel with Widget on Mobile Device
