Whatever the Search Widget does after configuration, can it be done behind the scenes?
1.Can I setup a search Widget to read from a Config file (lets say, config file has Map service URLs, Field to search on)
2. And then search and zoom ( by calling the Search/Find Dijit?)
Solved! Go to Solution.
Sowjanya,
I think you can use search widget to search something behind the scenes like this code snippet.
searchWidgets = widgetManager.getWidgetsByName("Search");
if (searchWidgets.length > 0) {
var search1 = searchWidgets[0];
if (search1 && search1.searchDijit) {
search1.searchDijit.search(text);
Sowjanya,
