How do you set a custom javascript widget's size?
11693
02-10-2015 05:12 PM
LanceGoens
I'm brand new to working with dojo and the WAB. I'm creating a custom widget and I'm trying to control the default size of the container "window" that opens to house the widget. It seems that if I add the widget to the header widget container/controller, the default size is 360 pixels wide and 100% tall. I've removed it from there and added it to the "1" widget button in the WAB and now I can at least adjust the size of the widget's container window once it's open, but more importantly... How/where do I set the size of the widget's container when it opens?
Web AppBuilder Custom Widgets
LanceGoens
You guys may have pin pointed the correct way to do it but I found an alternative and since I'm working on a prototype / proof of concept project, quick and dirty is what I'm after.
In the app's config.json file, I added the widget and placed a position node/element with it in the json. I'm guessing I may have actually stumbled onto the correct way to do this but I'm not sure. i haven't retested the widget in the header controller with this setup but I think those widgets are locked into the default panel size. Placing this widget in the "1" spot (near the home button) is sufficient for my need and actually preferable because I need to be able to move the window to interact with the map under it. Anyway, here is the code I added to config.json in the app root where the "width" and "height" control the panel the widget panel's size:
        "position": {
          "left": 55,
          "top": 45,
          "width": 650,
          "height": 500
        "placeholderIndex": 1,
        "id": "_5",
        "positionRelativeTo": "map",
        "name": "SplicingSchedule",
        "label": "Splicing Schedule",
        "version": "1.1",
        "uri": "widgets/SplicingSchedule/Widget",
        "config": "widgets/SplicingSchedule/config.json"
by Anonymous User
Not applicable
In this case it sounds like you need to create a custom Panel.
Navigate to the Panel location (you should find this in your app's config.json) and make a copy of Panel.  Set the panel properties in your custom panel, then configure your widget to use the custom panel.
Hope this helps.
FC_Basson
As steve way says, you can use a custom panel CSS size class.  In "js/main.js" when the tool is created with toolbar.createTool(tool, panelClass), replace panelClass with your own custom class, which you also define in "css/styles.css".
So in main.js => var mytool = toolbar.createTool(tool, "myPanel")
and in styles.css => .myPanel{height:200px /*custom height*/}
LanceGoens
        "position": {
          "left": 55,
          "top": 45,
          "width": 650,
          "height": 500
        "id": "_5",
        "version": "1.1",
