How do I add "suggest" functionality to geocoder in web app builder
8450
11
03-30-2015 07:22 PM
BrandonKeinath1
I've created a geocoder using 10.3 arcmap that we are running in a web app builder application hosted on our 10.3 arcgis server.  I understand from a conversation with ESRI that the "suggest" functionality introduced at 10.3 server doesn't work within web app builder.  Is there any way to work around this?
Brandon
BrandonKeinath1
Hi Stan,
I'll check out the post you mentioned.  Are you able to share the reference data?  I'm still having issues with my locators and I'm wondering if it is something special in your data or the schema.
Brandon
StanMcShinsky
Brandon,
when you create a locator it takes a snapshot of your data and embeds it in the locator. That is why you would need to rebuild a locator if the data changes or gets updated. You do not have to share the reference data then, just the locator. Can you share the rest endpoint for your locator? Or maybe you could private message it to me. or if you wanted you could sent me the data and I can try it from my end. Let me know what you think.
-Stan​
