How do I add a dijit/form/DateTextBox to a widget?
3082
08-01-2017 08:26 AM
DirkVandervoort
From dijit/form/DateTextBox — The Dojo Toolkit - Reference Guide
Uses claro css.
In widget.html:
<div>
 <label for="date1">Drop down Date box:</label>
 <input type="text" name="date1" id="date1"
 data-dojo-type="dijit/form/DateTextBox"
 required="true" />
</div>‍‍‍‍‍‍
And in widget.js I've defined dijit/form/DateTextBox.
Yet my results are less than pleasing
Any direction and/or clue would be appreciated. TIA
RobertScheitlin__GISP
Dirk,
   In your widget.js do you have _WidgetsInTemplateMixin as part of your declare array?
Dirk,
DirkVandervoort
DOH! Got it working. Needed to define DateTimeBox:
define(['dojo/_base/declare',
    'jimu/BaseWidget',
    'dijit/form/DateTextBox',
    'dijit/_WidgetsInTemplateMixin',
    'esri/graphic' ],
  function(declare,
      BaseWidget,
      DateTextBox,
      _WidgetsInTemplateMixin,
      Graphic) {
    //To create a widget, you need to derive from BaseWidget.
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
      // Custom widget code goes here
by Anonymous User
Not applicable
Hi Dirk,
could you show me the whole code for your widget?
so the html and js files?
I still can't get my datetimebox working...
