How can I customize the query widget?
8924
22
11-17-2017 10:12 PM
VatsalDave2
I need the solution for clearing the input parameters on selecting "clear this result" in the Query widget. Will appreciate a quick response from Esri Tech Support.
VatsalDave2
Hi Robert,
PFA the config file. All the data for the query is coming from the same layer.
Regards,
Vatsal
RobertScheitlin__GISP
Vastal,
   What version of WAB?
VatsalDave2
I am using version 2.3.
Sorry, should have mentioned that. My mistake.
Sent from my iPhone
That might be it then. I was testing using 2.6 and could never duplicate that issue.
VatsalDave2
I should have mentioned that. But I need to use 2.3 for some reasons.
Sent from my iPhone
Maybe time to upgrade then
VatsalDave2
I am unable to do that. Can there be a solution for WAB 2.3?
Sent from my iPhone
Not that I know of.
VatsalDave2
Thank you very much, Robert for so much of your time and for all the help.
Regards,
Vatsal
Sent from my iPhone
AdamPodlewski
Hi, Robert
Can you suggest where to force outStatistics option to be used in query widget?
Regards.
