How can I change the widget group icon in WAB (Dev Edition)?
4832
6
03-03-2017 10:55 AM
FrancescoTonini2
Can anyone help me understand whether it is possible to change the default icon of the widget group from a WAB Developer Edition template? By default, the group widget icon looks like a folder with three dots in it is used when grouping multiple widgets into a single named group (see attached image). Thank you!!
Widget group icon in Web AppBuilder
RobertScheitlin__GISP
Francesco,
  Ahh. I forgot they changed that. You can add a unique icon for each group by adding an icon property to the group object in your main config.json. I added line 4:
    "groups": [
        "label": "New Group",
        "icon": "jimu.js/images/group_icon2.png",
        "widgets": [
If you made a change it would affect all group icons not just one.
Just replace or edit the image:
FrancescoTonini2
Thanks! I see, that's what I was afraid of. Are there workarounds for using a different group icon for each custom group I decide to create?
Francesco,
    "groups": [
        "widgets": [
CCWeedcontrol
I was able to change the group icons but the color of the icon it self is blue so it make my graph icon hard to see. How do i change the color of the widget button?
CC,
   That is a tough one. The Launchpad theme assigns the background colors for those buttons at random.
CCWeedcontrol
aw i see, thanks for the reply.
