Headless AWAB Widget
4033
03-27-2015 01:06 PM
KevinPenner
I am having a tough time deploying an AWAB widget which has no UI. When I drop the Widget in the stemapp it seems to deploy fine, except it only lets me place the widget into one of the following 3 places.
I'd like to have this widget appear in the default group and load on start:
Can anyone help?
Kevin
RobertScheitlin__GISP
Kevin,
   You will need to add it to the client\stemapp\predefined-apps\default\config.json then.
Kevin,
KevinPenner
Thank you Robert! The directory was: client\builder\predefined-apps
Kevin,
   Be aware that it has changed to the location I provided in version 1.1, I forgot to ask which version you were on.
