Has anyone had luck wrapping typescript widgets for WAB?
1387
10-21-2019 06:03 AM
BradWilson1
I just found this example (GitHub - gbochenek/wab-test-example: ESRI Web App Builder Widget built using a wrapped widget conven... ) and I really like the ideas proposed. I am however completely new to typescript so I can reaching out to see if anyone has used this design pattern with typescript that they could share/explain. Thank you in advance for your help!
shaylavi
Hi Brad,
A bit of a late response, but I found this live demo that shows how to work with TS when developing widgets -
YouTube
You can use the Yeoman generator tool to quickly start with new widgets in modern es6 and wrap it with TS -
GitHub - Esri/generator-esri-appbuilder-js: Yeoman generator to help customize Esri's WebAppBuilder
Shay
Shay
