Get coordinates in planar
1018
05-31-2022 10:38 AM
JamesCrandall
Edit: I am open to any solution -- simple is better, GeometryService/Engine whatever works.
Back again, lots of interesting requirements lately!
This time I'm attempting to get the x/y values of point geometry in 102100/3857 as planar coordinates (wkid 2881).  Is there a simplified projectAs() function in the ESRI Javascript 3.x?
I've been attempting to implement projection but not having success with the overcoming errors with the geoTransformation.
               layer.layerObject.queryFeatures(query, function (f) {
                            const inSpatialReference = new SpatialReference({ wkid: 102100 });
                            const spSpatialReference = new SpatialReference({ wkid: 2881 });
                            var geoT = projection.getTransformations(inSpatialReference, spSpatialReference)
                            for (var i in f['features']) {
                                var facObj = Object.assign({}, f.features[i]['attributes']);
                                const point = new Point(f.features[i].geometry, inSpatialReference);
                                const projectedPoint = projection.project(point, spSpatialReference, geoT);
                                facObj.x = projectedPoint.x
                                facObj.y = projectedPoint.y
I have a facObj that I just need to apply the xy planar coordinate values.
JamesCrandall
Solved with client-side esri/geometry/projection
projection.load().then(function (evt) {
                            var geoT = projection.getTransformation(inSpatialReference, spSpatialReference)
                            const projectedPoint = projection.project(point, spSpatialReference);
                            this.facObj.x = Math.round(projectedPoint.x);
                            this.facObj.y = Math.round(projectedPoint.y);
JamesCrandall
