Get Area value and update before apply Edits in Edit Widget
3626
11
12-04-2017 09:03 PM
KrishV
Hello All,
I'm trying to update one attribute value using Polygon Area in Edit Widget. I'm using before-apply-edits event to do so. For calculating area of polygon I'm using geometry service. Please find the code below:
onBeforeApplyEdits: function (evt) {
          if (evt.adds != null) {
              var feat = evt.adds[0];
              var geometry = feat.geometry
              var geometryService = new GeometryService("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
              //geometryService.on("areas-and-lengths-complete", outputAreaAndLength);
              var areasAndLengthParams = new AreasAndLengthsParameters();
              areasAndLengthParams.areaUnit = GeometryService.UNIT_SQUARE_METERS;
              areasAndLengthParams.calculationType = "planar";
              geometryService.simplify([geometry], lang.hitch(this, function (simplifiedGeometries) {
                  areasAndLengthParams.polygons = simplifiedGeometries;
                  geometryService.areasAndLengths(areasAndLengthParams);
              geometryService.on("areas-and-lengths-complete", lang.hitch(this, function (evtObj) {
                  var result = evtObj.result;
                  console.log(result.areas[0]);
                  area = result.areas[0];
                  feat.attributes.no_of_areas = Math.round(area / 25);
                  setTimeout(lang.hitch(this, function () {
                      evt.target.applyEdits(null, [feat], null);
                  }), 100);
                  debugger;
Attributes are getting updated but unable to save. Please suggest how to proceed.
Regards,
Krish
Tags (1)
RobertScheitlin__GISP
Krish,
   This is what I have working (tested):
add new requires:
define([
    'dojo/_base/declare',
    'esri/tasks/AreasAndLengthsParameters',
    'esri/tasks/GeometryService'
  function(declare,
    AreasAndLengthsParameters, GeometryService) {
Attach the before edit event lines (30 - 39) in _getTemplatePicker:
      _getTemplatePicker: function(layerInfos) {
        this._layerObjectsParaForTempaltePicker = [];
        array.forEach(layerInfos, function(layerInfo) {
          if(layerInfo.featureLayer &&
            layerInfo.featureLayer.getEditCapabilities &&
            layerInfo.featureLayer.getEditCapabilities().canCreate) {
            this._layerObjectsParaForTempaltePicker.push(layerInfo.featureLayer);
        }, this);
        // change string of templatePicker is empty
        this._defaultTempaltePickerEmpeyStr =
          esriBundle.widgets.templatePicker.creationDisabled;
        if(this._canCreateLayersAreAllInvisibleFlag) {
          esriBundle.widgets.templatePicker.creationDisabled =
            this.nls.noCanCreateLayerAreCurrentlyVisible;
        var bottomStyle = this._configEditor.toolbarVisible ? "" : "bottom: 0px";
        var topStyle = this._configEditor.useFilterEdit ? "top: 115px" : "top: 18px";
        var templatePicker = new TemplatePicker({
          featureLayers: this._layerObjectsParaForTempaltePicker,
          grouping: true,
          rows: "auto",
          columns: "auto",
          style: bottomStyle + ";" + topStyle
        }, html.create("div", {}, this.domNode));
        templatePicker.startup();
        templatePicker.on("selection-change", lang.hitch(this, function(evt){
          var selected = evt.target.getSelected();
          if (selected) {
            var featureLayer = selected.featureLayer;
            if(this.evtHandler){
              this.evtHandler.remove();
            this.evtHandler = on(featureLayer, 'before-apply-edits', lang.hitch(this, this.onBeforeApplyEdits));
        return templatePicker;
onBeforeApplyEdits function (I did make a change line 5):
      onBeforeApplyEdits: function(evt) {
        if(evt.adds != null) {
          var geometryService = jimuUtils.getArcGISDefaultGeometryService();
          geometryService.simplify([geometry], lang.hitch(this, function(simplifiedGeometries) {
          geometryService.on("areas-and-lengths-complete", lang.hitch(this, function(evtObj) {
            setTimeout(lang.hitch(this, function() {
            }), 100);
Kirsh,
  So are you saying it is failing at line 28?
KrishV
Hi Robert,
Yes. applyEdits is not working and I don't see any errors in console. "areas-and-lengths-complete" is asynchronous and this fires after edits are completed.
Regards,
Krish
Krish,
   Is it complaining that evt.target is undefined or null or that evt.target.applyEdits is not a function. What is the error?
KrishV
Robert,
I don't see any error message. This lines runs but the attributes are not getting updated in the feature layer.
Krish,
  Hmm.. Try adding this line 2 so we can be sure you still have a reference to a FeatureLayer:
  console.info(evt.target);
}), 100);
KrishV
Hi Robert Scheitlin, GISP,
I Added console.info and have a reference to Feature layer.
Regards,
Krish
Krish,
   So how are you testing that the edits are not getting applied?
KrishV
Hi rscheitlinGISP‌,
After capturing new feature, I'm refreshing the browser and clicking on captured feature to see updated attributes in pop up.
Krish
Krish,
add new requires:
define([
  function(declare,
        }, this);
          grouping: true,
          rows: "auto",
          columns: "auto",
          if (selected) {
            }), 100);
