Find a point at a given distance along a line
16348
18
12-28-2016 12:13 PM
GregRieck
Hello everyone,
Does anyone have any experience with or sample code or sample geoprocessing events etc. that will return a point X,Y along a line (polyline) given a specific distance? For example if the polyline is 1000 feet long I want to know where along that line 250 feet is from it's starting vertex. I want the results as a point string format {"x" : -118.15, "y" : 33.80, "spatialReference" : {"wkid" : 4326}} so I can mark that location with an image on the web site.
Thank You,
Greg
TomSellsted
Greg,
Is the basemap in your app also in that projection? or is it web mercator?  If your basemap is in web mercator, you can set the outSpatialReference for the query to web mercator.  Something like:
query.outSpatialReference = new SpatialReference(102100);
Regards,
Tom
TomSellsted
Greg,
There was also a post from a couple of years ago that uses a similar method, but might work on your projection.
https://community.esri.com/servlet/JiveServlet/download/525576-1-135992/pointAlongLine.txt.zip
Regards,
Tom
GregRieck
Tom,
Thanks for the response, I was able to figure it out and get it working. Still doing some final testing but it's looking great. Again thanks for posting that project it was exactly what I needed.
Greg
TomSellsted
Greg,
You are welcome!  Glad you got things working!
Regards,
Tom
YueWu1
by Esri Regular Contributor
Good stuff!
GregRieck
Tom,
I have found a small issue with this method. It seems to always determine the position of the point along the line starting from the "From" point of the line. In some cases I need it to start from the other end of the line the "To" point of the line. How can I change the calculatePositionAlong so that it starts from the TO position and works toward the FROM position? I'm pretty sure I can come up with something that can be used to determine which way to start from.
Greg
TomSellsted
Greg,
Probably the simplest solution would be to reverse the order of the path points in the polyline used.  I have updated my example to show how to do this.  Here is a function that will reverse the path order:
function reversePolylineOrder() {
     var newPL = new Polyline(map.spatialReference);
     var newPath = [];
     for (var i = pl.paths[0].length - 1; i >= 0; i--) {
          newPath.push(pl.getPoint(0, i));
     newPL.addPath(newPath);
     pl = newPL;
Regards,
Tom
GregRieck
Tom, thank you for the continued support. This is where I got with what you provide me.
I got a few errors and fixed those by adding geometry as indicated below. However, after I  assign pl = newPL, pl has no geometry. Which is important because calculatePositionAlong uses it:
arrayUtils.forEach(pl.geometry.paths[0], function (coords) {
And I use it to create a new graphic used to display myimage at the found point along the line,
 var graphic = new Graphic(pl.geometry, myimage);
var newPath = [];
for (var i = pl.geometry.paths[0].length - 1; i >= 0; i--) {
newPath.push(pl.geometry.getPoint(0, i));
pl = newPL;
How can I make sure pl has geometry?
Greg
TomSellsted
Greg,
Sorry for the late reply. I am on the road today and have limited access to the internet.
I would set a breakpoint on the last line and then you can examine the values for both the pl and newPL variables. The code looks correct, the pl variable may not have a value set.
Regards,
Tom
46° 36' 17.86"N 120° 30' 18.23"W
