eSearch? Widget Question
1134
11-07-2016 05:42 AM
TimHayes1
I have 30 layers in my WebMap. The default is to have all 30 layers turned on. Instead of a user to have to go into the Layer List Window and turn 29 layers off, so they can view that 1 layer they want by itself, I want a user to be able to use a drop-down list to choose which layer they want to see. When these user selects a layer from this list, then the only layer they will see in the map window is the layer they selected from the drop-down list.
I know the eSearch selects features and this highlights them.
Is this possible? any ideas?
RobertScheitlin__GISP
Tim,
   Yes this is possible but there is not a widget out there that has this specific functionality. You would need to create a custom widget for this. A starting point might be the Layer Toggle Button Widget Version 2.1 - 08/01/2016 and these threads:
Turn On Layers on Widget Start
https://community.esri.com/thread/183044-how-to-remove-all-layers-from-a-web-appbuilder-app-dev
Tim,
