eSearch Widget Highlight Results Question
1084
04-06-2018 07:54 AM
TimHayes
Is there a way to set the eSearch Results to an Outline, not a solid results selection?
I am searching by polygon, but when the Results show up it highlights them as a solid polygon, no transparency. I would prefer it be highlighted using an Outline. Does the latest version of eSearch allow this to be done?
I have tried to Edit Default Search Symbology, no luck.
I have attached the Results I get so you can see what I am talking about.
RobertScheitlin__GISP
Tim,
  Sorry I am not sure how I missed this question. So when you edited the default Search results fill symbol did you adjust the transparency slider?
Tim,
