eSearch & WAB 2.7.
4731
14
01-26-2018 02:49 PM
CCWeedcontrol
Download both the latest eSearch & WAB 2.7, copied the eSearch folder to C:\GIS API\WebAppBuilder2.7\WebAppBuilderForArcGIS\client\stemapp\widgets and went to create a new app and i added the eSearch Widget and i was able to set it up but when i went to test it I go "Create Widget Error"Widget/eSearch/Widget". I tried the WAB 2.7 in firefox and Chrome and i get the same error. I did not edit anything in the WAB 2.7 or the eSearch folders.
Anyone else having this issue?
In Chromes browser console i get.
main.js?wab_dv=2.7:199 jimu.js init...
ConfigManager.js?wab_dv=2.7:136 Load Config: 887.1259765625ms
(index):1 Failed to load https://mapcase.deq.idaho.gov/arcgis/rest/info?f=json: The 'Access-Control-Allow-Origin' header contains multiple values 'http://******:3344, *', but only one is allowed. Origin 'http://******:3344' is therefore not allowed access.
MapManager.js?wab_dv=2.7:214 Load Map: 3382.7138671875ms
WidgetManager.js?wab_dv=2.7:114 widget [themes/LaunchpadTheme/widgets/Header/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/ZoomSlider/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/Coordinate/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/Scalebar/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/MyLocation/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/HomeButton/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/OverviewMap/Widget] created.
Widget.js?wab_dv=2.7:46 LocateButton::navigator.geolocation requires a secure origin.
WidgetManager.js?wab_dv=2.7:114 widget [themes/LaunchpadTheme/widgets/AnchorBarController/Widget] created.
WidgetManager.js?wab_dv=2.7:114 widget [widgets/Search/Widget] created.
AbsolutePositionLayoutManager.js?wab_dv=2.7:106 Load widgetOnScreen: 1238.56005859375ms
PanelManager.js?wab_dv=2.7:83 panel [_33_panel] created.
WidgetManager.js?wab_dv=2.7:116 create [widgets/eSearch/Widget] error:TypeError: Cannot read property 'length' of null
    at Function.n.fromHex.b.colorFromHex [as fromHex] (https://jsdev.arcgis.com/3.23/init.js:208:110)
    at Object._addCustomStyle (http://******:3344/webappbuilder/apps/2/widgets/eSearch/Widget.js?wab_dv=2.7:3913:30)
    at Object.postCreate (http://******:3344/webappbuilder/apps/2/widgets/eSearch/Widget.js?wab_dv=2.7:183:14)
    at Object.create (https://jsdev.arcgis.com/3.23/init.js:355:366)
    at Object.postscript (https://jsdev.arcgis.com/3.23/init.js:354:104)
    at new <anonymous> (https://jsdev.arcgis.com/3.23/init.js:200:129)
    at Object.createWidget (http://******:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js?wab_dv=2.7:320:16)
    at Object.<anonymous> (http://******:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js?wab_dv=2.7:112:35)
    at https://jsdev.arcgis.com/3.23/init.js:63:337
    at h (https://jsdev.arcgis.com/3.23/init.js:107:277)
Widget.js?wab_dv=2.7:60 Uncaught TypeError: Cannot read property 'name' of undefined
    at Object.<anonymous> (Widget.js?wab_dv=2.7:60)
    at Object.<anonymous> (init.js:63)
    at Object.c [as onwidget-created] (init.js:119)
    at Function.h.emit (init.js:124)
    at Function.h.emit (init.js:125)
    at Object.emit (init.js:117)
    at Object.<anonymous> (WidgetManager.js?wab_dv=2.7:131)
    at init.js:63
(anonymous) @ Widget.js?wab_dv=2.7:60
(anonymous) @ init.js:63
c @ init.js:119
h.emit @ init.js:124
h.emit @ init.js:125
emit @ init.js:117
(anonymous) @ WidgetManager.js?wab_dv=2.7:131
setTimeout (async)
(anonymous) @ WidgetManager.js?wab_dv=2.7:129
h @ init.js:107
q @ init.js:107
resolve @ init.js:109
(anonymous) @ WidgetManager.js?wab_dv=2.7:189
h @ init.js:107
q @ init.js:107
(anonymous) @ init.js:457
h @ init.js:107
q @ init.js:107
h @ init.js:107
q @ init.js:107
(anonymous) @ WidgetManager.js?wab_dv=2.7:1159
h @ init.js:107
q @ init.js:107
(anonymous) @ utils.js?wab_dv=2.7:172
init.js:114 TypeError: Cannot read property 'length' of null
    at Function.n.fromHex.b.colorFromHex [as fromHex] (init.js:208)
    at Object._addCustomStyle (Widget.js?wab_dv=2.7:3913)
    at Object.postCreate (Widget.js?wab_dv=2.7:183)
    at Object.create (init.js:355)
    at Object.postscript (init.js:354)
    at new <anonymous> (init.js:200)
    at Object.createWidget (WidgetManager.js?wab_dv=2.7:320)
    at Object.<anonymous> (WidgetManager.js?wab_dv=2.7:112)
    at init.js:63
    at h (init.js:107) "TypeError: Cannot read property 'length' of null
    rejected at a (https://jsdev.arcgis.com/3.23/init.js:108:174)
    at h (https://jsdev.arcgis.com/3.23/init.js:107:450)
    at q (https://jsdev.arcgis.com/3.23/init.js:107:203)
    at d.l.reject (https://jsdev.arcgis.com/3.23/init.js:109:488)
    at Object.<anonymous> (http://******:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js?wab_dv=2.7:125:21)
    at d.resolve (https://jsdev.arcgis.com/3.23/init.js:109:280)
    at Object.<anonymous> (http://******:3344/webappbuilder/apps/2/jimu.js/WidgetManager.js?wab_dv=2.7:189:13)
Error
    at d.then.b.then (https://jsdev.arcgis.com/3.23/init.js:110:97)
    at Object.<anonymous> (http://******:3344/webappbuilder/apps/2/jimu.js/BaseWidgetPanel.js?wab_dv=2.7:76:53)
    at Object.forEach (https://jsdev.arcgis.com/3.23/init.js:70:486)
    at Object.loadAllWidgetsInOrder (http://******:3344/webappbuilder/apps/2/jimu.js/BaseWidgetPanel.js?wab_dv=2.7:66:13)
    at Object.startup (http://******:3344/webappbuilder/apps/2/jimu.js/BaseWidgetPanel.js?wab_dv=2.7:55:12)
    at Object.g (https://jsdev.arcgis.com/3.23/init.js:197:400)
    at Object.startup (http://******:3344/webappbuilder/apps/2/jimu.js/OnScreenWidgetPanel.js?wab_dv=2.7:65:14)
    at Object.openPanel (http://******:3344/webappbuilder/apps/2/jimu.js/PanelManager.js?wab_dv=2.7:151:17)
    at Object.<anonymous> (http://******:3344/webappbuilder/apps/2/jimu.js/PanelManager.js?wab_dv=2.7:93:16)
    at https://jsdev.arcgis.com/3.23/init.js:63:337"
n @ init.js:114
(anonymous) @ init.js:114
filter @ init.js:71
h @ init.js:114
setTimeout (async)
h @ init.js:114
setTimeout (async)
q @ init.js:114
q @ init.js:107
l.reject @ init.js:109
a @ init.js:108
h @ init.js:107
q @ init.js:107
(anonymous) @ WidgetManager.js?wab_dv=2.7:125
h @ init.js:107
q @ init.js:107
h @ init.js:107
q @ init.js:107
h @ init.js:107
q @ init.js:107
h @ init.js:107
q @ init.js:107
h @ init.js:107
q @ init.js:107
CCWeedcontrol
I am lost too. I've re-download WAB 2.7 Dev and your eSearch Widget multiple times and keep getting that error.
RobertScheitlin__GISP
Export your app that you are having issues with and attach the exported zip it to a reply using the advanced editor here.
CCWeedcontrol
I have attached an app. There really much to the app as i was testing WAB 2.7.
Thank you for you help.
CC,
   So it looks like this is a issue on my side. Try changing the _addCustomStyle function in the Widget.js (way at the bottom of the file) to:
      _addCustomStyle: function(theme) {
        var customStyles = lang.getObject('customStyles', false, theme);
        if(!customStyles || !customStyles.mainBackgroundColor || customStyles.mainBackgroundColor === ""){
          return;
Line 3 is the change.
CCWeedcontrol
The eSearch widget seems to be working on all themes after making changes to line 3.
Thanks!
