eSearch spatial selection not working as expected
1453
11-09-2020 04:52 PM
NormB
I have an eSearch 2.13 for WAB question.  I've developed a website that is throwing me some unexpected behavior and I believe it's due to the data set but I can't seem to track it down. When I use the spatial selection tool and select in my case parcel after parcel the tool eventually "loses it" and picks a default set of 1000 records. The site address for the website is https://manitowocmaps.info/webapps/test/  I have also had a problem configuring the auto populate tools for this dataset and that is why I think it might have something to do with Joins in the base Pro Doc/Service but have been unable to put my finger on the issue.  The setup is a base set of parcels, joined in the project to a tax database which is then related to a permit database.  Has anyone else run into this issue with the spatial selection against this type of service setup? I can understand why the auto populate might not work as it would need to reach through the join to get the results list but can't figure out the spatial tool "losing it". Thanks in advance for any help or insight!
NormB
Thanks Robert,
I'll take a look at those configuration options and get back to you in the
next day or two... never thought of looking at those. tks!
Regards,
Norm
On Tue, Nov 10, 2020 at 12:26 PM Robert Scheitlin, GISP <[email protected]>
RobertScheitlin__GISP
Norm,
  Can you give me a step by step use case for me to use on your site link, that is having and issue with a "By Spatial" search?
NormB
Robert,
Thanks for jumping in!
I had my terminology mixed up. I intended to say select by shape. I have
the select by point tool as the default tool. Step 1. Zoom into the map so
that you can see individual parcels. Step 2. Select one parcel, then select
another single parcel. If you keep repeating this process of single parcel
selection eventually it will not select a single parcel but will default to
a 1000 parcel selection... it's always the same set of parcels that it
defaults to. Thanks!!
Regards,
Norm
On Tue, Nov 10, 2020 at 8:20 AM Robert Scheitlin, GISP <[email protected]>
Norm,
  One Issue I see if that you have chosen these two options:
Enable Buffer Graphic by default: true
Show Buffer Graphic options: false
So what this does is buffers any graphical selection by 50 feet (in your case).
I am not sure if that is the issue, but that is a unusual configuration.
NormB
Thanks Robert,
Regards,
Norm
