eSearch & Query widget compatibility issue
1328
09-18-2019 09:21 AM
JasonStanton__GISP
I am using WAB 2.13.  When I add the eSearch widget (2.12) and Query widget in the same app, the presence of the the eSearch widget causes the '.query-result-action-button' under the results tab of the Query widget to not open.
Any ideas on what might be causing this?
Any help would be greatly appreciated!
Jason
RobertScheitlin__GISP
Jason,
   OK I see you got a bad download of the 2.12 eSearch widget. re-download and you should be good to go.
Jason,
   I just tested eSearch 2.12 and the query widget in WAB Dev 2.13 and there is no conflict...
JasonStanton__GISP
I thought it was odd, so I started with a fresh copy of 2.13. only added those two widgets. did not configure the eSearch widget. configured the Query query widget using different layers (as well as WebMaps) and when i select the parcel, apply the search and try to click the 'more options' button nothing happens.  If I remove the eSearch widget it works fine.
Test app is here - ArcGIS Web Application
Jason,
JasonStanton__GISP
That was it!  Thanks!!
