eSearch 2.12 - Date clearing
2952
12
12-03-2019 05:50 PM
RodWoodfordOld
Hi Robert,
How do you clear date search fields on eSearch startup. Our users need to always select the clear fields option when starting eSearch searches that have date field searching included. See image below, where dates populate on startup. Any advice would be useful.
Also with unique field searching, is it possible for eSearch to hold onto the information after selecting the clear fields button to search again. It seems eSearch needs to repopulate these field every time the clear field option is selected, thus slowing down workflows. Any advice would be useful
cheers
RodWoodfordOld
Thanks Robert that did the trick. Will you be adding this change into your next release. It would be good to have maybe a tick box on dates settings to say clear field on startup.
cheers
RobertScheitlin__GISP
Rod,
   Yes version 2.14 will have a "Date fields default is empty" checkbox in the "Update Expression Value" dialog. I will release this soon now that I know there is nothing else that needs fixing.
RodWoodfordOld
thankyou
