esearch 1.1.1 not able to return results
10362
22
03-27-2015 09:40 AM
MarkYerington
I am getting the following error and the search button is not displaying in the widget.  Don't know whether this has anything to do with it.
Now I can't even do anything in the new widget since the search button is gone.
RobertScheitlin__GISP
Mark,
   Does your app happen to be public yet?
MarkYerington
I attached an image, of the console error. I hope it came across. It
shows the query string, but after that throws the 400 error.
Mark Yerington, GISP
MAGIC GIS Systems Analyst
3205 CEDAR ST | MUSCATINE, IA 52761
PH: 563.262.3316 | CELL: 563.260.4525
Mark,
   Unfortunately this is not enough info fro me to do anything with. Is your app public yet? If not can you download the app and send it to me?
MarkYerington
http://magic-gis.com/error/
Its out there now. Try a 0826352026 pin search.
Mark,
  You can not combine https and http in the app. Your App URL is "http://magic-gis.com/error/" and then you use "https://magic-gis.com/arcgis/rest/services/MAGIC_Landbase/MuscatineParcels/MapServer/0" in the eSearch config.
MarkYerington
Even when I make a request with https it still fails though.
MarkYerington
An invalid where clause or definition expression has been requested:
"(Search for Parcels AND Upper(PIN) LIKE Upper('%0826352026%')) AND
(Upper(PIN) LIKE Upper('%0826352026%'))"
This is a severe error on the server. Seems like a bad query expression
is being sent.
Mark,
  OK the infamous Definition Expression strike again. You have a definitionexpression defined in your json as "Search for Parcels"
"layers": [
      "name": "Parcel Search",
      "url": "http://magic-gis.com/arcgis/rest/services/MAGIC_Landbase/MuscatineParcels/MapServer/0",
      "definitionexpression": "Search for Parcels",
      "spatialsearchlayer": true,
      "zoomScale": 10000,
      "shareResult": true,
      "addToAttrib": true,
      "expressions": {
        "expression": [
            "alias": "Parcel Number",
            "textsearchlabel": "Search by Parcel Number",
            "values": {
              "value": [
                  "fieldObj": {
                    "name": "PIN",
                    "label": "PIN",
                    "shortType": "string",
                    "type": "esriFieldTypeString"
                  "valueObj": {
                    "value": ""
                  "prompt": "Parcel ID",
                  "textsearchhint": "Search by Parcel ID",
                  "sqltext": "Upper(PIN) LIKE Upper('%[value]%')",
                  "operation": "stringOperatorContains"
The documentation gives you this warning.
Warning:
This is an actual SQL expression that will limit the search results to the definition expressions criteria as well as the actual search SQL criteria
MarkYerington
Ok. Sorry for not being thorough in reading the documentation. All works
again.
Mark,
   No problem several have made this mistake that is why I put that warning in the help doc. Don't forget to mark any posts you found helpful as such.
