Esarch Widget within
1392
02-14-2018 10:53 AM
CCWeedcontrol
I am trying to use the Esearch widget by spatial "within" but keep getting no results.
Here are the steps i am taking.
1. Select impact area polygon with esearch "by shape".
2. click spatial tab, set search features of another polygon layer, there is feature within the impact area selected polygon
3.  and Use one of these spatial relationships: "within"
There is features of the search features layer that are with the select impact area polygon.
Not sure what i am doing wrong?
RobertScheitlin__GISP
CC,
   I have not had much luck using within either. I would suggest using contains instead.
CCWeedcontrol
sorry i mean with Enhanced Search widget, i wanted to make sure it wasn't just me.
entirely Contained give weird results if you line work is not perfect, it almost seems as the best option would be "Have their centroid in the source layer feature."
CC,
   Well, all the ArcMap options are not part of the API and that is one that is not.
CCWeedcontrol
I totally understand, thank you!
