Error When Creating Report with Report dijit
5611
14
05-06-2020 06:55 AM
joerodmey
I have tried to create a report using the report dijit and keep getting the following error "Create widget error widgets/Report/Widget". I've explored the following example with no luck Create a custom widget using the Report dijit—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS...
Below is my widget.js:
define(['dojo/_base/declare', 'jimu/BaseWidget', 'jimu/dijit/Report', 'jimu/dijit/PageUtils'],
function(declare, BaseWidget, Report, PageUtils) {
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget], {
    // DemoWidget code goes here
    //please note that this property is be set by the framework when widget is loaded.
    //templateString: template,
    baseClass: 'jimu-widget-report',
    postCreate: function() {
      this.inherited(arguments);
      console.log('postCreate');
    startup: function() {
	  this.report = new Report ({
		  footNotes: "Reported Generated by Terracon"
		  printTaskUrl: "http://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task",
		  reportLayout: {
			  "pageSize": PageUtils.PageSizes.A4,
			  "orientation": PageUtils.Orientation.Landscape
	  console.log('startup');
_onBtnPrintClicked: function(){
		var printData = [
		  addPageBreak: true,
		  type: "map",
		  map: this.map
		  title: "List of parks",
		  addPageBreak: false,
		  type: "table",
		  tableCols: 3,
		  data: {
			showRowIndex: false,
			rows:  [["Brookside Park", "1630 Brookside Avenue, Redlands, CA 92373", "34.045347, -117.209909"],
			        ["Crafton Park", "Wabash Ave & Independence Ave, Redlands, CA 92374", "34.060946, -117.140118"],
					["Ford Park", "Parkford Dr & Redlands Blvd, Redlands, CA 92374", "34.043828, -117.160692"],
					["Prospect Park", "352 Prospect Dr., Redlands, CA 92373", "34.039145, -117.172582"],
					["Sylvan Park", "601 N University St, Redlands, CA 92374", "34.059977, -117.168179"]],
			cols: ["Name", "Address", "Lat/Lon"]
			title: "Photos",
			type: "html",
			data: '<div style="height: 450px;"><div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/brookside.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Brookside Park</div></div>'+
			      '<div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/Crafton.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Crafton Park</div></div>'+
				  '<div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/ford-park.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Ford Park</div></div>'+
				  '<div style="width: 250px; margin-left: 10px; float: left; clear:left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/Prospect%20park.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Prospect Park</div></div>'+
				  '<div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/Sylvan%20Park.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Sylvan Park</div></div></div>'
        this.report.print("Redlands Parks", printData);
Any ideas?
Thanks
KenBuja
MVP Esteemed Contributor
In that case, you needed closing braces and parentheses at the end (lines 68 and 69). In addition, you were missing a comma in line 21.
  function (declare, BaseWidget, Report, PageUtils) {
      postCreate: function () {
      startup: function () {
        this.report = new Report({
          footNotes: "Reported Generated by Terracon",
          reportLayout: {
      _onBtnPrintClicked: function () {
        var printData = [
            addPageBreak: true,
            type: "map",
            map: this.map
            type: "table",
            tableCols: 3,
            data: {
            title: "Photos",
            type: "html",
            data: '<div style="height: 450px;"><div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/brookside.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Brookside Park</div></div>' +
              '<div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/Crafton.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Crafton Park</div></div>' +
              '<div style="width: 250px; margin-left: 10px; float: left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/ford-park.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Ford Park</div></div>' +
              '<div style="width: 250px; margin-left: 10px; float: left; clear:left;"><div><img style="width: 250px; height: 200px; float: left;" src="http://cityofredlands.org/sites/default/files/rda/Landmarks/Prospect%20park.jpg" /></div><div style="text-align:center; margin-bottom: 10px;">Prospect Park</div></div>' +
KenBuja
Is there an extra bracket in line 26? And line 33?
joerodmey
I played around with brackets and moved the btn function into the main function and still no luck. Updated code:
		  reportLayout: {
		var printData = [
		  addPageBreak: true,
		  type: "map",
		  map: this.map
		  type: "table",
		  tableCols: 3,
		  data: {
			title: "Photos",
			type: "html",
KenBuja
Try this. I've added line 30, a closing brace for the startup function and a comma. You need commas to separate the functions. What type of IDE are you using? A good one will highlight the paired brackets, braces, and parentheses, which is quite helpful in debugging.
            reportLayout: {
          var printData = [
            addPageBreak: true,
            type: "map",
            map: this.map
            type: "table",
            tableCols: 3,
            data: {
               title: "Photos",
               type: "html",
joerodmey
Tried this but still the same error
KenBuja
Are there any errors in the console?
joerodmey
It says missing } after property list
note: { opened at line 35, column 33
it also says TypeError: clazz is not a constructor
KenBuja
Can you post the entire script?
joerodmey
That is the entire widget.js file for this widget
KenBuja
          reportLayout: {
        var printData = [
            addPageBreak: true,
            type: "map",
            map: this.map
            type: "table",
            tableCols: 3,
            data: {
            title: "Photos",
            type: "html",
