Enhanced Search widget fails
987
11-27-2017 11:33 AM
NadiaTargulian
Robert Scheitlin, GISP
Hi Robert!
I use your great widget and it worked great until recently. Lately it returns "Search failed!" message with Parcels layer. Still works with all the other layers. In Firefox Network console in Response payload the correct feature is returned.  I am lost what may be causing this. in Arcmap the same selection returns  correct parcel as well.
Thank you for any hint you may provide,
Nadia
RobertScheitlin__GISP
Nadia,
  So there is no errors on your browsers console when the search fails? Has the parcel Layer schema (fields) changed recently?
DanielMunoz
I'm also experiencing the "Search failed !" but it happens more frequently when the search is perform from iPhone/iPad devices.
