eDraw widget
144814
251
02-24-2015 01:17 AM
JeremieCornet1
Ehanced draw widget for WebApp Builder for Arcgis
UPDATE 2018/05/09 (new Release v2.8.1) :
  • refactoring
  • use esri/geometry/projection (available since esri js api 3.24) instead of proj4js (external libs)
  • systematic use of geometry engine (no more mercator utils, geometry server...)
  • for polyline, the user can now add an arrow (available since esri js api 3.23)
  • live measure while drawing
  • WARNING : this release needs Esri API >= 3.24
Release 2.8.1 on Github
(Direct zip link : https://github.com/magis-nc/esri-webappbuilder-widget-eDraw/releases/download/v2.8.1/eDraw.zip )
Demo : https://apps.magis.nc/demo/eDraw/
Github  :
Wigdet's Features (improvments of standard Draw widget) :
  • add name and description fields on drawings
  • enable infowindow on drawings (selection)
  • on text drawing, no insert if no name.
  • on modification : enable geometry update (with snapping if wanted : CTRL) and preview symbology changes on the fly
  • list
    • add list of all drawings
    • actions on each drawing : modify / delete / [up / down] / zoom
    • all drawings : zoom, copy, delete, export
    • on drawing infowindow -> select drawing in list
    • on zoom on a drawing -> select drawing on map (and show infoWindow)
    • re-order graphics with drag&drop
  • import/export : allow users to export or import drawings (json format)
    • import can be done with file drag&drop in import popup
  • localStorage
    • dynamic saving on each drawing add/delete/update
    • on widget load : load drawings saved in local Storage
  • draws plus (initially from Larry Stout https://geonet.esri.com/people/Larry_Stout)
    • preview under mouse when adding text or point
    • for text, add font choice, font angle, bold, italic, placement and underline options.
    • add arrow menu for polyline
  • checkbox to hide drawing's layer (and therefore widget UI)
  • add of Nautical unit
  • measure's for points/polylines/polygons with automatic update on element's update (or delete). Measure's can be indidualy disabled/enabled on any graphic.
  • "On the fly" measure when drawing
  • defaults symbols can be specified in config's file
  • use of builtin projection engine (available since esri js api 3.24) instead of proj4js library
This message was updated by Jeremie Cornet (New Release)
Jérémie - MAGIS NC
GIS enthousiast, python & javascript lover
JeremieCornet1
Hi Kevin MacLeod‌, you must have a defaultSymbols -> MeasureSymbol defined in your widget's configuration
esri-webappbuilder-widget-eDraw/config.json at master · magis-nc/esri-webappbuilder-widget-eDraw · G...
I will package a release in the next days.
Jérémie - MAGIS NC
by Anonymous User
Not applicable
Yep, I sure do. Cool. Got it, thanks again! Maybe I will see you soon at dev conf.
BenjaminCumberland
If I enter a Point down and change the symbology to it, then go to Edit that Point, the symbology appears to keep choosing the Default Point Symbol instead of the chosen/correct symbology. All of the other geometry types correctly show the symbols, but not Point. Anyone come up with a fix for this, yet?
BenjaminCumberland
Nevermind, I figured out it had to do with these two lines:
this.editorSymbolChooser.showBySymbol(symbol);
this.editorSymbolChooser.showByType(this.editorSymbolChooser.type);
JhonnyGutierrez
hi,
I have the same problem, what did you do with the lines?
AlexSanders2
I have added the eDraw widget to the latest release of WAB 2.11 and noticed a bug. The widget is no longer allowing me to save any changes I make to an existing drawing.
I create a new drawing, go to my Drawing List screen, click the pencil button to edit/update the drawing, move the vertices, but when I go to click the save button, nothing happens. I can click the "reset" button and it will reset the drawing back to the original and I can click the "cancel" button and it will bring me back to the Drawing List screen.
Is anyone experiencing this issue?
JeremieCornet1
Hi Alex,
I can reproduce the bug.
I have to create a new release after full tests because my last commits may introduce some errors in differents backgrounds (than my dev environnement).
You can update the code with this modification (#fix no update possible · magis-nc/esri-webappbuilder-widget-eDraw@ede39f8 · GitHub ), meanwhile i am making a new release.
Jérémie - MAGIS NC
AlexSanders2
That fixed the issue, thank you so much Jeremie!
JeremieCornet1
Hi Benjamin Cumberland‌,
I will investigate this issue. It may be because of the multiple categories of style.
Do you reproduce the issue when using a symbol from the first category (base) ?
Jérémie - MAGIS NC
BGMUAdmin
Hi. New here. I've downloaded the eDraw widget and put the folder into the WebAppBuilderForArcGIS widget folder. How do I make it show up when adding a widget into AGOL app builder? I'm new to all this, so appreciate the help.
