eDraw widget
144560
251
02-24-2015 01:17 AM
JeremieCornet1
Ehanced draw widget for WebApp Builder for Arcgis
UPDATE 2018/05/09 (new Release v2.8.1) :
  • refactoring
  • use esri/geometry/projection (available since esri js api 3.24) instead of proj4js (external libs)
  • systematic use of geometry engine (no more mercator utils, geometry server...)
  • for polyline, the user can now add an arrow (available since esri js api 3.23)
  • live measure while drawing
  • WARNING : this release needs Esri API >= 3.24
Release 2.8.1 on Github
(Direct zip link : https://github.com/magis-nc/esri-webappbuilder-widget-eDraw/releases/download/v2.8.1/eDraw.zip )
Demo : https://apps.magis.nc/demo/eDraw/
Github  :
Wigdet's Features (improvments of standard Draw widget) :
  • add name and description fields on drawings
  • enable infowindow on drawings (selection)
  • on text drawing, no insert if no name.
  • on modification : enable geometry update (with snapping if wanted : CTRL) and preview symbology changes on the fly
  • list
    • add list of all drawings
    • actions on each drawing : modify / delete / [up / down] / zoom
    • all drawings : zoom, copy, delete, export
    • on drawing infowindow -> select drawing in list
    • on zoom on a drawing -> select drawing on map (and show infoWindow)
    • re-order graphics with drag&drop
  • import/export : allow users to export or import drawings (json format)
    • import can be done with file drag&drop in import popup
  • localStorage
    • dynamic saving on each drawing add/delete/update
    • on widget load : load drawings saved in local Storage
  • draws plus (initially from Larry Stout https://geonet.esri.com/people/Larry_Stout)
    • preview under mouse when adding text or point
    • for text, add font choice, font angle, bold, italic, placement and underline options.
    • add arrow menu for polyline
  • checkbox to hide drawing's layer (and therefore widget UI)
  • add of Nautical unit
  • measure's for points/polylines/polygons with automatic update on element's update (or delete). Measure's can be indidualy disabled/enabled on any graphic.
  • "On the fly" measure when drawing
  • defaults symbols can be specified in config's file
  • use of builtin projection engine (available since esri js api 3.24) instead of proj4js library
This message was updated by Jeremie Cornet (New Release)
Jérémie - MAGIS NC
GIS enthousiast, python & javascript lover
JeremieCornet1
New release (see first post) :
- debugs from spelletier
- points' measure (with client side reprojection if needed)
- support of WAB 2.1
Jérémie - MAGIS NC
DevonBise
jeremie34‌, this widget is fantastic!  I am fairly new to the Developer version of Web AppBuilder and when I came across your widget I was immediately sold!  My only issue that I have come across is that when I added it into my application (v. 2.1) I am unable to export a drawing.  It almost doesn't recognize the click.  Is this an issue on my end alone?  Thanks!
JeremieCornet1
Hi Devise91‌,
Thanks for the bug report, i will correct it today and release a coorrected version.
Jérémie - MAGIS NC
JeremieCornet1
New release (export's refactoring). See first post.
DevonBise‌ : the regression is corrected
Jérémie - MAGIS NC
DevonBise
BEAUTIFUL! Thank you for the quick reply and fix!  I LOVE this widget.  Keep killing the custom widget game, Jeremie!
AwesomeEvan
Does this still work with WAB dev 2.2?
I put it in a fresh install of WAB and it shows up in the widgets with a broken icon and a blank page when clicked on?
RobertScheitlin__GISP
Evan,
   Make sure the widgets folder name does not contain "master" in it.
AwesomeEvan
I read that the folder name should be the same as what is defined in the manifest.json... I renamed the folder "eDraw" and it now works... i previously just unzipped it as "esri-webappbuilder-widget-eDraw-2.1.2"
Thanks Robert
FinbarGillen
Where in the code can you expand the widget container... want to expand the container so the edit buttons can be seen on first sight.
JeremieCornet1
Finbar Gillen‌ I want the widget to fit in its panel so i will implement some specific css for the launchpad theme.
EDIT : i will release a corrected version but you can correct it now by adding this lines to the css file :
.jimu-widget-edraw .draw-table td, .jimu-widget-edraw .draw-table th{
   padding:5px;
Jérémie - MAGIS NC
