Draw polyline and show map infowindow
1602
09-03-2020 12:12 PM
KafilBaig
In my custom widget i have a datagrid and on row click i am showing the location and infowindow on map. For Point and polygon the infowindow shows correctly but for polyline it doesn’t show infowindow or draw the polyline for the geometry returned . It blanks out the map. Please guide me if am doing something wrong. Please find the code below.
Var polylinesymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,255,0]), 5), new Color([255,255,0,0.25]));
var clickPointGraphics = new Graphics(featureSet.features[0].geometry, polylinesymbol);
clickPointGraphics.setInfoTemplate(InfoTemplate);
this.map.graphics.add(clickPointGraphics);
this.map.infoWindow.SetTitle(title);
this.map.infoWindow.SetContent(Content);
this.map.infoWindow.show(featureSet.features[0].geometry, this.map.getInfoWindowAnchor(featureSet.features[0].geometry));
var stateExtent = featureSet.features[0].geometry.getExtent().expand(5.0);
this.map.setExtent(stateExtent);
RobertScheitlin__GISP
Kafil,
   You are passing a Polyline to the map infowindow show method and it is expecting a point geometry.
<Point> location -  Required - An instance of esri.geometry.Point that represents the geographic location to display the popup.
KafilBaig
I am unable to highlight the polyline geometry retrieved from my service .
Also is the code correct what am doing or should I modify anything
Did you read my reply?..
You are are try to show the info window using a polyline geometry.
