definition expression
10147
9
05-27-2015 06:50 AM
LefterisKoumis
Hello. I am newbie in the web app builder area. How can I apply a definition expression on a layer to draw only the features that meets the criteria. I looked into the layerInfos in the json file but I am not sure iof you can you use a definition expression. Thanks.
DanielStoelb
Lefteris,
You might want to check out the following: LocalLayerWidget and AccessifizrWidget Additionally, there is the possibility of modifying the code to do definition expressions.  Check out this thread for details: Local Layer Widget .
RickeyFight
Lefteris,
This thread shows how this can be done.
Custom Floor switcher widget WAB
LefterisKoumis
Thank you. I see how is done in the code. I was hoping to see a configuration file (perhaps json file)that you can define the layers that you use in the map and the definition expression to define which datasets to display. I am trying to migrate to JS from FLEX where you can do this in the configuration file.
Suggestions?
RickeyFight
Lefteris,
I was working on this to make it a widget but I have been distracted for a few weeks.
Maybe Robert Scheitlin, GISP​ can help you.
Also look at some examples here: Web AppBuilder Developer Edition – Customization Resource List
ZhifangWang
Hi Lefteris,
Have you tried the Query Widget? I think you can filter a layer in Query Widget UI and also in the configuration json file.
Query widget—Web AppBuilder for ArcGIS | ArcGIS
Query—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
DanielStoelb
Lefteris,
LefterisKoumis
Thank you. Robert's response to your question provided the info I was looking for.
JeremieCornet1
You can filter your layers in the AGOL (or PORTAL) map used in your app.
Jérémie - MAGIS NC
GIS enthousiast, python & javascript lover
StanMcShinsky
This would be better for me too.
-Stan
LefterisKoumis
Yes, That's correct. However, in my case where I have multiple layers is a lot easier to modify the definition expression in a configuration file rather than creating a map for each case.
Thank you.
