ClusterLayer.js popup problem
8089
11
02-13-2015 07:59 AM
NEvatt
I am currently using the ClusterLayer.js file to create clustered points as in the example here.  I am very happy with the results within a the JavaScript Api, but I am now trying to use it within a custom widget in the Web AppBuilder.  It works almost perfectly except for one problem, the popup window closes on its own within about a second of opening it.  I can't find any errors and have done everything I can think of to single out the issue with no luck.  Has anyone experienced something similar before?
I was thinking that potentially there was an issue with between the infowindow popup and the PopupTemplate that is used in the demo, but I tried using the InfoWindow popup instead, but that didn't fix it either.
I have posted my code for the widget.js file here, however, I am currently unable to post a link because the firewall set-up that we have in our company.
Nat
deleted-user-RAnWn8DDSd1P
did you ever figure this out?  i get the same disappearing popup after a second.
StevenHaslemore
This line will stop the hide from the empty WAB popup results, preventing the cluster layer popup from being removed too.
this.map.infoWindow.visibleWhenEmpty = true;
