Change width of summary widget??
1542
05-10-2019 06:46 AM
MarquesMunson1
I am trying to change the width of the Summary widget that is displayed in my application using WAB DE. I have located the style.css file (\WebAppBuilderForArcGIS\server\apps\{AppID}\widgets\Summary\css) to change the width but the code that I located only changes part of the widget. See before and after screenshot below.
Before:
summary widget full
After:
summary widget 55%
I am trying change the width of the gray area to match the blue summary area. I have provided code below. Any help is greatly appreciated!
summary widget code
RobertScheitlin__GISP
You need to add this css rule to your apps theme common.css
.jimu-widget-summary {
  width: 55% !important;
MarquesMunson1
It worked! Thanks so much!
