Change splash widget button text in WAB
634
11-02-2018 06:49 AM
joerodmey
How can I change the text of the button on the splash screen widget in WAB? Need to keep the button want to change the text to "Continue" from "Accept"
RobertScheitlin__GISP
Joe,
???... The splash widget has an OK button not an accept. If you are really talking about the Splash widget then the text of the button is controlled in the widgets settings window. On the appearance tab there is the "Button text" setting where you can change the buttons text.
