Change png icon's background color dynamically for feature in feature layer
6909
15
04-25-2017 05:18 AM
ZdeněkSoldán
I have a point feature layer created from feature collection. As symbol for features in this FL is a png image with transaprent background. For every feature I have a html code of color readed from web service. Is it possible to change the background color for every feature using this hex code?
I tried a pictureMarkerSymbol:
var symb = new PictureMarkerSymbol("images/trafLight.png",12,25);
var colorHex = Color.fromHex('#'+ String(item.color));
symb.setColor(colorHex);
var geometry = new Point({"x":"-"+item.geometry.y,"y":"-"+item.geometry.x,"spatialReference":{"wkid":102067}});
var graphic = new Graphic(geometry);
graphic.setSymbol(symb);
features.push(graphic);
The color doesn't change and if so I think it would change color of the border lines not the background color.
ZdeněkSoldán
Robert,
in this link is printscreen from online font viewer http://imgur.com/a/0IFv4
so from the prinscreen I think that my icon should be \0040. Am I wrong?
And to my step 4 - the folder with fonts has the name fonts already maybe it's not clear from my post but the path to the 4 files TraficLight.eot, TraficLight.svg, TraficLight.ttf and TraficLight.woff already was WebAppBuilderForArcGIS\server\apps\apID\widgets\nameOfTheWidget\fonts
RobertScheitlin__GISP
That would be \eu0040
ZdeněkSoldán
Robert,
in my font the icon in on the place of the upper A so when my code is
var textSymbol = new TextSymbol('A', new Font("20pt", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "TraficLight"));
it works!
But this way I know only how to change color of the TextSymbol but is it possible to change only the background color of TextSymbol?
ZdeněkSoldán
Robert,
I used a halo property of the TextSymbol and it's good enough for me.
So thank you a lot for your help.
Zdenek
KumarHarish
Zdeněk,
Robert suggestion is  right.  Alternative convert the PNG image into SVG format.  Use the https://developers.arcgis.com/javascript/3/jssamples/graphics_svg_path.html tutorial to change the color of icon
ZdeněkSoldán
Kumar,
Thank you. This method works for me but it change directly the color of my svg picture but I want to change only the background of it.
