change on-screen icon placeholder size
1344
10-03-2019 09:52 AM
HelenZhou
In WAB application at version 2.13, I would like to change the icon's place holder size of an Off-panel, on-screen widget. How do I do? thanks for any help.
Helen
RobertScheitlin__GISP
Helen,
You are right in 2.13 it has changed to BaseLayoutManager.js in the jimu.js folder (lines 21 and 22).
_createOnScreenWidgetIcon: function(widgetConfig){
      var iconDijit = new OnScreenWidgetIcon({
        panelManager: this.panelManager,
        widgetManager: this.widgetManager,
        widgetConfig: widgetConfig,
        configId: widgetConfig.id,
        map: this.map
      if(widgetConfig.position.relativeTo === 'map'){
        html.place(iconDijit.domNode, this.mapId);
      }else{
        html.place(iconDijit.domNode, this.layoutId);
      //icon position doesn't use width/height in config
      html.setStyle(iconDijit.domNode, jimuUtils.getPositionStyle({
        top: widgetConfig.position.top,
        left: widgetConfig.position.left,
        right: widgetConfig.position.right,
        bottom: widgetConfig.position.bottom,
        width: 40,
        height: 40
      iconDijit.startup();
      if(!this.openAtStartWidget && widgetConfig.openAtStart){
        iconDijit.switchToOpen();
        this.openAtStartWidget = widgetConfig.name;
      this.onScreenWidgetIcons.push(iconDijit);
      return iconDijit;
I believe this is the thraed you are looking for then:
https://community.esri.com/thread/171233
HelenZhou
Thanks Robert. I have read the thread, It looks like the code has been changed at version 2.13. I am not able to see the correspondent codes. I have changed jimu-widget-onscreen-icon in \jimu.js\css\jimu.css. It doesn't work. Do you have any idea?
Thanks
Helen
Helen,
        map: this.map
      }else{
        width: 40,
        height: 40
      return iconDijit;
