Can context menu and infotemplate coexist for the same location
3795
11-16-2015 04:59 PM
LefterisKoumis
In flex, I was able to create a context menu and a tooltip (infotemplate) for the same point on a gL.  It seems that in JS is either one or the other. If I script out the infotemplate, the context menu appears, otherwise I will see the tooltip only.
so can they coexist?
this.createcontextmenu();
this.setinfotemplate();
  on(myGraphicsLayer, 'mouse-over', lang.hitch(this, function (event)
  this.map.graphics.clear;
  var graphic = event.graphic;
  if (graphic.attributes.name === "my point")
  this.map.infoWindow.setFeatures([graphic]);
  this.map.infoWindow.setContent(myGraphicMarker.getContent());
  this.map.infoWindow.setTitle(myGraphicMarker.getTitle());
  this.map.infoWindow.show(event.screenPoint,
  this.map.getInfoWindowAnchor(event.screenPoint));
  this.map.graphics.on("mouse-out", lang.hitch(this, function ()
  this.map.infoWindow.hide();
  createcontextmenu: function(){
  ctxMenuForGraphics = new Menu({});
  ctxMenuForGraphics.addChild(new MenuItem({
  label: "info",
  onClick: lang.hitch(this, function (event)
  if (selectedGraphic != null)
some code
  label: "Delete",
  onClick: function ()
some code
  ctxMenuForGraphics.startup();
  on(myGraphicsLayer, 'mouse-over', lang.hitch(this, function (evt)
  if (evt.graphic.attributes.name === "my point")
  selectedGraphic = evt.graphic;
  ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
  on(myGraphicsLayer, 'mouse-out', lang.hitch(this, function (evt)
  ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
setinfotemplate: function()
  var infotip = new InfoTemplate();
  tip = "<font color='#FF0000'>some text</b></font>";
  infotip.setContent(tip);
  infotip.setTitle("Location Info");
  myGraphicMarker.setInfoTemplate(infotip);
RobertScheitlin__GISP
Lefteris,
  No you can not have a infoWindow and a context menu using on mouse-over. You can have a standard infoWindow (which requires a click of the graphic) and a context menu though.
createGL: function() {
        var tip = "<font color='#FF0000'>some text</b></font>";
        this.myGraphicMarker = new Graphic(new Point(-84.3900,33.7550), new SimpleMarkerSymbol(), {"name": "my point"}, infotip);
        this.myGraphicsLayer = new GraphicsLayer();
        this.myGraphicsLayer.add(this.myGraphicMarker);
        this.map.addLayers([this.myGraphicsLayer]);
        var ctxMenuForGraphics = new Menu({});
          label: "info",
          onClick: lang.hitch(this, function (){
            if (this.selectedGraphic !== null) {
              //some code
          label: "Delete",
          onClick: function (){
            //some code
        on(this.myGraphicsLayer, 'mouse-over', lang.hitch(this, function (evt){
          this.map.graphics.clear();
          if (evt.graphic.attributes.name === "my point"){
            this.selectedGraphic = evt.graphic;
        on(this.myGraphicsLayer, 'mouse-out', lang.hitch(this, function (evt) {
          if (evt.graphic.attributes.name === "my point") {
Lefteris,
          label: "info",
              //some code
          label: "Delete",
            //some code
LefterisKoumis
Thank you Robert. I was hoping for the mouse-over. I guess we cannot replicate all flex functions to dojo and vice versa.
