Calling a function from Attribute Table widget?
5559
16
10-27-2017 07:08 AM
AnnCrystal
The attribute table widget has a function _switchTable which toggles attribute table. I would like to call it from a off panel widget. I looked into Communication between widgets- but it provides methods to fetchData. I am little confused. Any thoughts? Robert, have done anything in this line?
Thanks in advance
AnnCrystal
Thanks Robert for the tips.
Dojo is not going away so I am not sure about:
Sitepen is no longer doing anything with Dojo
My Sitepen reference was regarding training- Let me elaborate-I was planning take a Dojo online workshop which Sitepen used to host. But, they redesigned their website and all the pages which mentioned about the workshop schedules disappeared. So, I am stuck with no options for a jump-start training:(
AnnCrystal
Robert Scheitlin, GISP wrote:
Ann,
  Ahh, now I see what you were saying about the on event handler. So the issue I see in your code is that _AttributeTable is likely out of scope inside your on event handler. So you need to use lang.htich to get around that.
var _AttributeTable = this.widgetManager.getWidgetsByName("AttributeTable");
html.setAttr(this.domNode, 'title', this.label);
d = domConstruct.create('div');
on(d, 'click', lang.hitch(this, function{
  _AttributeTable._switchTable();
}),d);
Or you can use:
this._AttributeTable = this.widgetManager.getWidgetsByName("AttributeTable");
on(d, 'click', function{
  this._AttributeTable._switchTable();
},d);
Hi Robert:
I added the code to the widget. But on clicking the button, nothing happens. What can be wrong?
My full code of Widget here:
define([
'dojo/_base/declare',
'jimu/BaseWidget',
'dojo/_base/html',
'dojo/on',
'dojo/_base/lang',
'dojo/dom-construct',
'dojo/dom-class',
'dojo/topic'
function(
declare,
BaseWidget,
html,
on,
lang,
domConstruct,
domClass,
dojoTopic) {
var clazz = declare([BaseWidget], {
baseClass: 'jimu-widget-AttributeTableToggle',
icon: 'images/icon.png',
startup: function() {
this.inherited(arguments);
on(d, 'click', lang.hitch(this, function(){
domClass.toggle(this, "selected");
dojoTopic.publish('attributeTable/toggle', "selected")
}),d);
// html.place(d, this.domNode);
return clazz;
RobertScheitlin__GISP
Ann,
   I can see from this that you are pretty new to JS coding. There should be errors in your browsers console for sure, assuming the widget even loads.
You have this line in your code:
But you you don't have this.widgetManager defined any where.
define([
    'jimu/WidgetManager',
  function(
    WidgetManager,
You are adding a div:
But there is not style of class that specifies the height, width, color, etc.
Then you have commented out actually placing the div in your widgets domNode:
AnnCrystal
Thanks Robert. Yes, I am new to js programming and that I have to jump in Dojo right away for my internship. I was trying to modify an old widget code which places div and closes the table using a div tag "selected". However, that stopped working. Then, I saw that Attribute table widget has a function _switchTable() and was trying to implement it. But I am confused about how to call it without even using "d" as in
and this line:
}),d);
I was hoping to call that function without creating the variable "d" as this function need to be called on widget button click. Is there a simple way to do that  on the "on click" event? Thanks
Ann,
   So am I understanding you to say that you really do not want the widget to have a panel or UI you just want it to fire the switchtable method when the widget icon is clicked?
AnnCrystal
Yes Robert, that's correct. I want to toggle Attribute Table when widget icon is clicked.
Then you should look at my Layer Toggle Button widget for guidance:
https://community.esri.com/docs/DOC-8592-layer-toggle-button-widget-version-22-01132017
